What A/f guage is everyone running
jfaub63
il.
42 years
2015 Pro S 800
What a/f gauge is everyone running and do you like it. I'm getting ready to add one, I'm already running a bullydog so im looking towards the docking station.
Not sure if this helps but I have a PCV with auto tune module and the PD300 display. Also had Jaws weld the additional bung for the O2 sensor in the pipe. Works great.
Bully dog and the Ballenger motor sports afr500. I got this idea from doc . The big bright red digital read out is very easy to see.
I use the bully dock docking station. Love it because you can datalog your afr and everything else so it makes dialing in clutching and tune super easy
Out of curiosity, why do you display Throttle on your BD?
I had throttle positioning up because I was trying a new head design and if it did det. I could catch at what throttle position it did it. This way I could add fuel. My engine is ported ,so.
I have the docking station on its way. Where did you mount it and where did you pull power from ? Thanks
I mounted my bd, the opposite side of key. Drilled a hole, threaded bd docking station through.
Just plug it in to were dw plugs in
divyou have any pictures? Where exactly does the Dw plug in?
