What is the correct base idle voltage
JimCamp
Curtis michigan
The computer says one thing and in the mechanics tech tips it says something lower? Mine currently is .898 which the computer says is out of spec? This is on a 15 shorty ,,so if I'm checking should I just change the tps just cuz? The new software won't let you go to the next screen till the error is corrected?so in team tips its in the 600-700 range and in the computer its in the 900-990 range?
Yep, correct doc.
And if your voltage is lower then 0.900 @idle on tps.you'll foul plugs and won't idle @1700-1800 rpm.
Your sled should idle and jump a little from 1700-1800 on the 15 models
Well it's now at .925 and did the valve relearn,, when I started it would only pull 8000 with the clutching
I had in it,,,,now with no changes it now pulls 8400 and just sounds angry now!wish I had checked this last season
Been chasing clutching for a month now!
