Bruiser
I recently acquired a 1994 XLT Special that hasn't been ran for a few years. The choke lever broke and after removing the carburetors, the choke plungers were froze. Got the plungers out and replaced, along with the choke cable. Thoroughly cleaned the carbs when they were out. Replaced the drain lines and put carbs back on sled. Siphoned as much old gas as I could out of the tank and replaced with 2 gallons of fresh non ethanol gas along with some sea foam. Squirted a little carb cleaner in the airbox and the sled fired and quit. After doing this several times, put some lube in the cylinders aloong with a little gas and machine ran until the gas ran out. As long as carb cleaner is sprayed intermitantly into the airbox the sled will run. Tried removing fuel lines from the pump and blowing everything out and just don't seem to be getting any fuel to the carbs. Looking for assistance. Thanks in advance for any help you can give. BCN
