Justin gunnink
- 1
- 23
- Canada
- Canada
- 1
- 2003 Polaris 550 super sport fan
I have a 2003 Polaris 550 super sport fan. I had to rebuild the top end (gaskets and pistons) but went into the bottom end to check the bearings and seals which were all good. I put the engine back together, went through the carbs as the initial problem was it was idling very high and had low compression. When taking it a part, the gasket between the top half and cylinder was missing a section which pribabky caused an air leak and the high idle, but I put it back together and it still has a high Audi and now a scrapping noise. I looked around and noticed that my secondary clutch doesn’t stay in a fixed position it can slide up and down the jack shaft. Is this normal???
