Any solid yellow wire is hot all the time. You can tap into the yellow wire anywhere on the machine. If your tach has wires (yellow/hot and brown/ground) attached with screws and eyelets on the back of the tach put eyelets on your helmet cord and use the same screws. You eliminate splices that way.
