12 volt power ?
Indy Bill
Michigan
1999 indy 600 xc sp
I just picked up a 99 indy 600 xc sp and it is a pull start only sled. I was wondering where you can wire in a cord for a heated helmet visor?
Thanks
Thanks
Can usually tap into the rear light as it goes unit the seat.
Any solid yellow wire is hot all the time. You can tap into the yellow wire anywhere on the machine. If your tach has wires (yellow/hot and brown/ground) attached with screws and eyelets on the back of the tach put eyelets on your helmet cord and use the same screws. You eliminate splices that way.
