1999 polaris indy 500 XC gas leak ???
Olbaidhh
WI \ MN
I have a 1999 polaris indy 500 XC that will not leak a bit of gas when stored or running in the garage... but on the trail it leaks gas like a sieve , not out of the carbs or into the cylinders ... any ideas?
850Switchback
CT
2020 Switchback XCR
2013 Switchback Pro R
Probably a leaking fuel line somewhere. The ethanol gas eats the lines in the older machines and turns them hard and brittle, they then crack and leak.
Olbaidhh
WI \ MN
Why then does it not have a drop in the garage sitting for weeks or idling? That is what I cannot figure out.... does this model just eat the gas if the carbs are off could that be it.... but it doesn't run like its rich at all???
850Switchback
CT
2020 Switchback XCR
Could only be weeping until the vibration of the machine makes it worse, or its on the pressure side of the fuel pump. This is one you where are going to have to pull the airbox out of the way and start looking.
If its still the original fuel lines, I can guarantee thats whats failing as they get rock hard with age and start cracking everywhere.
Olbaidhh
WI \ MN
Ya but I start it in the garage and nothing leaking on the pavement or that just is not enough to get it to leak enough it has to be ridden and bounced around, must be the issue. What about a crack in the tank but higher up when its full or coming out of the overfill ? That is kind of what it seems like its doing. The 2003 XC 600 I have only needs gas one time for every 2 stops of the 500XC
850Switchback
CT
2020 Switchback XCR
There is a hose barb the fuel supply line connects to around 3/4 up the fuel tank. It is sealed by a rubber grommet the barb pushes thru. That could be failing and be leaking. There is also the tank vent at the top of the tank that has a vent hose that runs up the steering shaft.
Like I said above, you are going to have to pull the airbox and start looking around for signs of a leak, even lift up the rear bumper and get the fuel sloshing around in the tank.
All that rubber hose and seals in the system are very old now and were never intended for ethanol fuels, so likely dry rotted and failing. I had to rebuild the entire fuel system in my 2000 xc700 a few years ago, surprised yours lasted this long. The intank pickup hose is known to crack and fall off so you should think about just replacing it all.
