2008 IFT IQ Touring (750 turbo) -Help?
Chucker
Grand Marais, Minnesota
2008 Polaris FST IQ Touring
Does ANYone understand the ins/outs of this sled's turbo - engine light (flashing) with no apparent "problem" -- and does it really take a dealer with equipment to reset the check engine light?? :-(
Administrator
Admin
There should be code sheet for those flashes in the service manual.
Administrator
Admin
There aren't though. "solid" indicates engine issue. "flashing" indicates turbo issue. That's as far as it goes. :-(
That sucks.. might have to take it to a dealer, I am sure they can plug into it.
Chucker
They can but I did last year and they basically said: "Take it home and replace this ($275) valve before the wastegate. - That's all it can be." ---- I did and after a few rides it went off again. (+ the dealer is 2 hours away :-( ). That's why I wish I could at least turn the light off and see if it keeps happening - but I've been told that's not possible...?? ---- So, I'm searching here for someone whose experienced all this - Damn, ya think there'd be SOMEbody?? It ain't "THAT" old.... :-(
Administrator
Admin
Try disconneting the battery both positive and negative for a few days.
850Switchback
CT
2020 Switchback XCR
There were guys making conversion harnesses to plug those into automotive OBD2 code readers, they apparently use similar codes to generic OBD2. You'd have to do some searching to see what works,
I also remember reading about boost leaks being pretty common on those, something about a hose barb/ hose on the intake manifold that is a known leak point. Also some box that sees boost pressure was known to leak as well.
Chucker
Thank you! - I'll see what I can find on that stuff.
850Switchback
CT
2020 Switchback XCR
If you need to pressure check components MityVac has a handpump setup that can pressurize
