axxasult
2017 600/800 SWITCHBACK ASSAULT 144
. AXYS IFS: 42.5" Ski center to center distance
. 0.531" diameter SwayBar, same as Pro-S, reduce inside ski lift
. Front bulkhead cooler, tunnel coolers/protectors
. IGX 144 Rear Suspension, Tipup rails
.. 2 rear torsion/hairsprings
. W/E Comp. Adj. piggyback needle IFS
. W/E Comp. Adj. piggyback NO needle FTS coilover shock
. W/E Comp. Adj. piggyback NO needle RTS no coil shock
.. NO SnowCheck upgrade option for Hi-Lo speed compression adjustment of shocks
. Message Center 4.3" LCD gauge
. Integrated semi-rigid underseat storage.
. ProTaper 7/8" alum. flat Handlebars, 3.5" (89mm) Riser
. PowderTrac Hybrid Running Boards 56% open space
. 7.063" Chaincase center distance, like Rush/SB137
. 600cc Gears 1.86 22:41-70 1.35" Cobra, 2.11 19:40-68 2.0"
. 600cc Gears 1.86 22:41-70 1.75" BackCountry INTL
. 800cc Gears 1.74 23:40-70 1.35" Cobra, 2.10 20:42-70 2.0"
. 144 x 1.352 Cobra 2.52" pitch / 144 x 2.0 Series 4.0 stock OR snowcheck
. INTL 600 version 144 x 1.75" BackCountry 2.52" pitch
. Black Pearl stock color with alum. tunnel rails & spindles
. 600cc SBA $12,199US/13499CDN stock, ES + $400/500CDN
.. $12,599US/13899CDN Snowcheck colors & options
. 800cc SBA $13,499US/14599CDN stock, ES + $400/500CDN
.. $13,899US/14999CDN Snowcheck colors & options
AFTERMARKET TRACKS AVAILABLE for the Switchback Assault/SP 144
. 144 x 1.22" Ice Attak XT 2.52" pitch 47 lb. full clip studded Camso# 9203H 1ply
. 144 x 1.352" Cobra 2.52" pitch 44 lb. full clip Camso# 9107H 2ply
. 144 x 1.5" CrossOver 2.52" pitch 50 lb. full clip Camso# 9003C
. 144 x 1.6" ICE Cobra 2.52" pitch 50 lb. full clip studded Camso# 9315C 2ply
. 144 x 1.6" Cobra 2.52" pitch 49.5 lb. full clip Camso# 9316C 2ply
. 144 x 1.75" BackCountry 2.52" pitch 46 lb. full clip Camso# 9143C 1ply
. 144 x 2" Challenger 2.52" pitch 53 lb. full clip Camso# 9875M 1ply
