Chiefcheese
- Messages
- 246
- Age
- 61
- Location
- Wisconsin
- Country
- USA
- Years Snowmobiling
- 45+
- Snowmobile
- 15 Anny Rush 800, 16 PRR LE Switch 800
??????????????????Well I guess I am going to try a set of these out. Indy Specialty. Will let you know if there's any issues. Looks like sealed in oil.
That's a lot of ???????????????????
I was questioning the sealed in oil. Thats why I put your text in bold and underlined itThat's a lot of ?
Some brass bushings are impregnated in oil. when we change them out on machines at work some come that way they supposebly last longer.Sealed package. Bushings in liquid. ??
what I would like to know after you installed when you pull up on ski tip. Does it take out the movement of the spindle forward and back. Mine moves about 3/8-1/2 inch I want to tighten this upMy set was a little tight to get in but they are much better than the stock.
Yes. No slop on mine.what I would like to know after you installed when you pull up on ski tip. Does it take out the movement of the spindle forward and back. Mine moves about 3/8-1/2 inch I want to tighten this up
