JohnnyBravo
Gates belt is roughly 37mm wide or 1 7/16". Not sure what the width is on the Poo OEM belt. Won't know until tomorrow.
Every Polaris that I've had needed shims removed, until this one. I have less than .010" clearance with the 1177 belt, and can't get the Gates to the bottom of the clutch. I did not measure the shim stack, but I'm thinking there were 2 .050's, a .032 and a .020 for a total of .152", if Polaris still uses the shims from past years.Unless you have already reshimmed the spyder to less than .020 for a oem belt, doubtful you will need to reshim for Gates. Polaris sends these out with .030 to .050 belt clearance oem. With the Gates mine had .018 clearance before reshim.
It did have a light film of oil on the crank, and it looked like the clutch had rotated on the crank, as you could see rings around the stub. Wiped off clean with no galling of either the stub or clutch hub. I have only started and drove the sled enough to get it off the truck and into the garage. Glad I looked at this before riding it.Polaris factory uses a very light film of oil on the crank because sleds sit for long periods sometimes. That's why it was easy with clutch puller .
I've seen pretty much the same myself.I've also found that it is important to torque bolt run the sled then retorque the bolt on these I've seen a few that were loose after running with only the Initial torque applied.
Hey Brock, Whats a good weight to get? We r gearing to 1.74 and using a gates belt. I see some talk on the daltons. A bit pricey but easy to adjust. Not sure on other types as we are new to doing our own mods.Good post.
Clutching can have a lot of debates.
The meat and bones of clutching is the primary weight and secondary helix. Springs are for fine tuning.
My style of clutching is run as heavy as weights as possible and using the softest springs.
Belt to sheave clearance for trail sleds is better when it's around 0.010"- 0.020" as to much clearance may cause the belt to slip over time/wear.
Gear ratios are a huge player too
To be honest.Are adjustable weights recommended??
Ok, thx, maybe you guys can steer me in the right direction so im not out to lunch with my set up. Going by what ive read,If you are not going drag racing every weekend then yes grab a set of Dalton QAP3s.
Even for drag racing they serve the purpose well enough for the average guy.
Whats your recommendation? I was told there are sled lengths in the helix.IF YOU ARE GOING TO LEAVE THE STOCK HELIX, I WOULD NOT PUT THAT SEC. SPRING IN.IMO
Ok, any recommendation?? Helix? Spring? Helix spring combo??IF YOU ARE GOING TO LEAVE THE STOCK HELIX, I WOULD NOT PUT THAT SEC. SPRING IN.IMO
the 22/38 with 68 pitch chain has less dog leg then the 1.74 ratio by the way.Ok, thx, maybe you guys can steer me in the right direction so im not out to lunch with my set up. Going by what ive read,
gearing to 23/40
gates belt
120-310 pr
155-222 2nd
70gr (add 2 for gates)
for now stock helix (still learning on this topic)
We ride in maine, nice fast groomed trail.
I didn't notice that on the chart. I have the gear and chain already but can always return and get 22,38. How important is the longer dog leg??the 22/38 with 68 pitch chain has less dog leg then the 1.74 ratio by the way.
A good helix for fast trail is 50/44 , like doc said .
Damn that's creative!My clutch had too much aluminium so I got rid of some:
A little haircut off the top
Just a true up, gonna use this spot
spider spring pocket
Added a little weight with a custom shim to "untuck" the weights
View attachment 902 View attachment 903
