PA Pro
I have a 16 pro s 800 with a bmp stage 1 Bikeman kit. Im running a P2 secondary and im not getting full shift out and im not sure what to look for. Marked primary with a marker and lacking close to a half inch. Clutches are warm but not hot after long hard pulls.
Geared to 1.74
120-310 Primary spring
SSI weights 1,0,1
50-44 FP Dalton
140-200 Spring
Sled revs 8400-8450 has great low end outta the hole but flat up top. Slower than stock 17 pro s.
P2 clutch was floated and was checked with alignment tool. Im a bigger guy at 6'4" probably 285 full gear im wondering if the helix may be to big? Sled has 140 picks and 1.25 track. Any help would be great.
Geared to 1.74
SSI weights 1,0,1
50-44 FP Dalton
140-200 Spring
