Can't wait! Talked to dan and he said that he sells his new weights with heavy tip weight that will be installed in my clutch. Will the heavy tip weights pull the 50-44 full progressive helix? When its time ill send in a new gates belt for indexingI'm running a gates belt,so is haulin,doc,bigfuse ,pros,etc....
Works and wears good . Plus it's cheaper.
I'm gonna try an epi and Carlisle this winter too.
Good your getting your clutch balanced and machined. It will run a lot smoother plus less stress on other parts too. Make sure you get your clutch indexed for the belt your using.
I would leave your clutching the way it is and try first.
