Cutler tm
cody geyer
Loganton pa
'16 rush pro s
Just installed a set of tm 60-70 in axys 800 and my engagement is now 4500. Those of you that use these weights is this the normal ? 10-68 was around 3800 before. They rip, but.... man this seems high.
120-310
60-70tm 3/8 tip, 1" heel
Cg
What is the belt to sheeve clearance? They may have the heals cut on these and you might have to shim the spider
120-310
Cg
Ditch the 120-310 and put in a 110-290. Load a 3/4 inch first, second a 3/8, and lastly a 1 inch screw. You're way too light unless you're still using the Team secondary.
You'll probable end up around 63-66gr. with those weights the have a very aggressive shift profile and will act 3-5gr. heavier than what they weigh
they work grat if you have good traction, they however will overshift easy in loose conditions and rpm will be a little low.
