Fogging
Heres a video i made were you can prime your bottom end and oil your bearings by cycling the oil pump
So, power to the ecu, or power just the pump?
Just an FYI for Bikeman Performance customers, I developed a tune to help fog the motor with our Bully Dog tuner. The tune is free for anyone that purchased a Bully Dog through us. Send me an e-mail at neal@bikemanperformance.com with your ECU serial number and Bully Dog serial number attached and I'll send it over.
I prepeared my sled for the summer using fogging oil. After 2 pulls the sled started right up yesterday. The sled is running really, really rough with heavy white smoke! Is this normal? If I give it a little throttle it sounds like the engine is going to blow up. It shakes pretty bad.
I had the clutch off for maintenance....after I put it back on the vibration went away. Is the shaky behavior typical if clutch is not on? Never an issue with the Yamaha's I had in the past
