hunterjo
has any one tried to adjust float setting on older carbs ( ihave 1998 Polaris 700) looks like pin that float piviots on and the hole in main body of carb are .040 difference. what I am saying is hole was drilled way to big. I think kelim hide this mistack and tried to fix it by by putting brass insert in float body to take up some of the clearance. if I am wrong let me know. I have never seen where the pin and carb main body has had that clearence . ( pin .096 and hole .146) it should be a snug fit between the two ( ichecked another set of carbs from same year and had same problem. one last thing the holes in carb body are round and show no wear. I do not think they are wear out.
