Welll dealer relearned power valves,tps, deflection, sled was back to normal actually turning more rpms then ever sled hit 26 hours back to square one running an average 7100 rpm , once in a blue moon it will run 8000... not very impressed if I'm gonna have to screw with tps and valves every 12/13 hours any familiar situations??
Suspension is a 144 w 2" didn't tuck limiters track tension goodWhat's your suspension set up?
Clutch set up?
Gear ratio?
Clutches aligned ?
Leaky exhaust?
What's your suggestion for primary I just find it weird how pulled awesome then didn't and reset valves/tps then pulled back to normal and back to shit snow/ridding didn't change or clutching just curious why it would go outta wackYour biggest problem is the primary weight your using ,tip weight and the primary spring. You have it set to load motor hard and need perfect hero snow to make it rev properly.
You got those weights loading motor hard cause of profile, then your loading it even harder with tip weight , then using a soft primary spring on top(275).
Your set up needs to change a little and be more trail friendly. This is the problem I see so far, not your valves.
Which Cutler weights do u have? IT's or TM's ??Suspension is a 144 w 2" didn't tuck limiters track tension good
Clutch primary 70-80 cpc weights w 71g weight added at tip 140/275 white/gold spring secondary stock
Gear ratio 23/43
Clutches good
Last weekend sled turning 8300 climbing to 84-8450 I know it's supposed to be 8250 but in deep snow that's what it turns so on trail it's a little high rpm but this weekend I literally lost 1500 rpm sometimes sometimes turn 7 sometimes turn 7200 and gradually climb to 7600 had valves reprogrammed AGAIN and now turning 7600 climbing to 78-7900 but didn't check tps but wtf don't want to have to relearn valves and tps every 300 miles ?
What dealers aren't performing is the:
E-VES Cable Full-In to Full-Out Travel: Approximately.63 –.71″ (16 -18 mm )
This is critical .
ITWhich Cutler weights do u have? IT's or TM's ??
What's your elevation?
Rider weight?
Which IT weights did you get? Polaris or cat?IT
500-1500
225
Polaris 70-80Which IT weights did you get? Polaris or cat?
What's the base weight??
This means a lot
That's to heavy of a base weight. I see what's going on now.Polaris 70-80
Well it's none of the above dealer tried different clutches temp sensor exhaust sensor valves tps same thing motor is coming apart Monday as soon as they get pistons and a block in there was 11 over heat codes but only one showed up on dummy light and honestly thumb is constantly flicking through speed and temp so not sure how this happened but I know they run better around 120-130 degrees so I keep an eye on it not sure what to say kinda mad that I only saw light once and temp never seemed to get hotThat's to heavy of a base weight. I see what's going on now.
Your rpm is way down sometimes cuz your set up has to have perfect conditions to get proper rpm( hero snow or ice). Warmer temps or heavier snow will bring your rpm down very low cuz of this aggressive set up. I don't think you have a valve problem?
The weight you have needs to be near 60-62 grams base weight (up shifts so quick)
Putting in a 70 gram base weight and only one gram added ain't gonna work with the cpc ITs profile.
Do you have anymore weights to try?
Well, the way your clutch set up you mentioned isn't helping rpm.Well it's none of the above dealer tried different clutches temp sensor exhaust sensor valves tps same thing motor is coming apart Monday as soon as they get pistons and a block in there was 11 over heat codes but only one showed up on dummy light and honestly thumb is constantly flicking through speed and temp so not sure how this happened but I know they run better around 120-130 degrees so I keep an eye on it not sure what to say kinda mad that I only saw light once and temp never seemed to get hot
