ogrant
- 27
- 54
- Innisfil, Ontario
- Canada
- since 1995
- 2016 pro s 800 snowcheck
Well from what I have read so far this is a great site, so much info. Been lurking for awhile.
I have a 2016 pro s 800 switchback, all stock with the cobra track.
I just want to fine tune what I feel is a bit of a flat spot around 80mph to, around 96mph. It seems to go like a bastard up until 80 then it seems like it's not pulling like it should for a 800 between 80-96.
It will rev usually to 8200-8300 and sit there while doing this so I am not getting any rpm loss.
I have checked my belt deflection, belt clearance, track tension and all seems like the tips that I have seen here on this site. It has the 22/37 1.68 gears in it and all stock clutching. The only mod I have done is getting the primary balanced(no vibrations now).
Now I could care less about top speed, my buddy with his modded turbo cat can own the lake for all I care, I just like trail riding, corner to corner pick up and go. But when I hit the fields in between the bush trails I want to let'r go and feel that it is working right.
I didn't know if I should throw a little weight at it with a new primary spring. I have searched around the site, but the info is just a bit scattered. I know it's here, I'm just having a hard time putting it all together for my issue...if it is even an issue at all.
