Need rear track shock polaris
smarchand1
South Dakota
1998 Polaris XLT SP 600
I am rebuilding 1998 Polaris XLT SP 600 with XTRA 10 121" style suspension. I just noticed the rear track shock shaft was broken from upper mount and a chunk is missing from center of shaft. It is a Ryde AFX adjustable compression shock OEM # 7041694 and cannot find one online. I cant measure the total extended length because chunk missing to order a replacement. Is there somewhere that sells aftermarket that would fit this sled or does anyone know the dimensions of this particular shock? Or am I going to have to try and salvage a used one somewhere?
Thanks- Shane
Pro116
Moderator
Moderator
Shiocton,WI
I thought them came with Fox shocks? Are you sure someone didn’t replace it with a ryde shock at some point.
TheBadger
South Dakota
2019 RMK 155
Did you ever find a shock for your 98 XLT? Kimpex USA says they have a shock for that sled with the 121' track.......
