jgale.rm
- Messages
- 19
- Location
- Clear Lake, WI
Has anyone used the PCV? I'm sure if you have done the work you won't want to share your maps, but I will ask anyways. Anyone here willing to share your maps?
I've done some maps at dtr and another guy has too. There should be some out soon to share.
Fuel and timing to clean it up from factory.
I said it in another thread in here already.What gains or differences did you find?
It works different than the Powercore V the Bullydog actually reprograms the ECU not manipulate the stock map like the PCV does. It also reads engine codes, and can record data logsI see bully dog makes one for the axys to bit it's more expensive. Does it allow you to adjust more then the pcv
Too bad you can't trust PC5s
We have had multiple failures , never did get a positive answer from power commander what the issue or issues are .I'm not understanding?? Why can't you trust a pcv?
First 1 we had issues wIth was in 2013 with no timeing control ...believe it is the timing control version only that there having problems with?
Great Dave I'm happy for you ! Just telling you guys are experience with the pcv, if you run 1 I would have a spare cause it's no fun walking ...I ran a PC3 on my 07 Harley, a 5 on my 2010 IQ800 and currently a 5 on my 2010 Harley. No issues with any.
You can just unplug it and ride home on the stock map.
Hmmmm, I have never seen a pcv fail yet??We have had multiple failures , never did get a positive answer from power commander what the issue or issues are .
Not saying they don't, just my experience.
