Power values
Fort kent
First 13 hours on sled had to get power valves "reprogrammed " was only turning 7300-7800 rpm then sled ran awesome after now have 26 hours it's doing it again!! Wtf is there a fix for this ???
First go round, did valves require cleaning at the same time?
If yes, what oil are you running?
Did it throw a code, or just wouldn't pull top RPM's? Mine is only pulling a max of 8150 RPM's. Dropped off at dealer this morning for the following checks:
-E-VES Exhaust Valve Cable length check.
-TPS in spec.
-Exhaust Temp. sensor reading in spec.
First time it came on for a split second time a heat "dummy" light came on once noticeably but says it over heated 11 times curious why light didn't come on more often cause I keep an eye on temp24/7 and never seemed to run hotter than 135
