shwantz34
- 69
- Ste-Brigitte -De-Laval
- Canada
- 2019
- Polaris Indy 850 XC 129
The piston tolerances are needed but it's also about the weight of piston( piston, rings, clips, wrist pin& bearing) . Stock and others being 580+ grams is a little heavy . Get the total weight down around 500 grams with a great designed piston, proper tolerances and you have less stress on other parts . This can equal more reliability and hp in the right hands
So what makes would do the trick ?
Brock Why don't you just tell us which pistons have "total weight down around 500 grams with a great designed piston, proper tolerances"
Witch makes ?
I just want to refresh my sled for next winter with the best reliable piston kit available for my sled. (better performance also if possible)
Oem or other , i don't mind. I just want to keep my motor top notch. Winter is short , i don't want to loose riding
time because of piston failure or ring wear.
and the winner is ................
P.S i understand all what you say before , about blue priinting the engine, but for now i only want a reliable
stock motor, with a pipe and PCV, I don't have the budget to put 3-4 k $ at a race shop for now.
