Select monitor
Vectorman05
S.central Mn
I know this is for older sleds but I just got a brand new select monitor for both the 650rxl and the 500 efi's for what I would have spent on a laptop and cable for the free pc version. this is going to make life so much easier!
Here it is,never been used:) depending on when I get home I'll be playing,i mean using it tonite
Hooked it worked as it should, found out idle fuel adjustment is supposed to be between 2 and 3 volts,I'm at 4.52 idle spec is 2.7 degrees, I'm at 3 not to far out. Tried making a short video,I didn't like it,as I tinker I will keep you guys posted.
Sounds great... this is awesome info for the site. Thanks
i have the Polaris service manual with all the specs in it,I'll try to get it posted. I did find out the tps is off a bit,but not far enough to trigger a code. This is exciting to know I can get this back to where it's supposed to be:)
Awesome, Nice Job!! Is that manual in paper form or PDF?
You can post them in a new thread and say what each pages is... for what sleds it covers and then we can FAQ link them once they are all posted.
I started it in the wedge forum,first couple pages. This will take awhile,so please be patient:)
I can move them over but it will still need the notes... It will be awesome info for the site. Great job!!
