What im saying is gearing didn't really make a difference. 10hp and gearing low like what is recommended on a bunch of threads that doo should've wiped Polaris ass and flushed. But really wasn't much difference. And both sleds lost a little on 2nd run. So they were running pretty consistent. Considering the temp and the terrain they were racing on. The 1.61 gear still showed the fastest speed. When in other threads guys are saying the lower gear is showing faster speed.On snow where the weight transfer works in Polaris's favor instead of making the rider let off to get control its a much different story
Idk, wasn't really a good shootout. But comparing to what was run. I dont see much difference
Above Brock says ProS had 1.61 gearAccording to parts diagram 2016 rush pro s 800 with hacksaw track have 1.78 gearing. I agree gearing not a factor if you see photos from the race the Polaris again had skis pointed to the sky I'm saying uncoupled skid launching on dirt hard to get a good start where you can keep on the gas without flipping over backward. Weight forward doo is a great chassis for dirt dragging.
Where as on actual snow nothing can touch the uncoupled axys launching out of the hole
Ripsaw 2 is 1 1/4.Above Brock says ProS had 1.61 gear
I think the 1.68 gearing came with the 1.325 track. And think that was snowcheck option. Pretty sure these were floor models with the 1 1/4 track
I think lowering ratio in my short track is gonna hurt traction. I dont wanna regear then have to add another 60 studs. I think i should be able to get 1.6 gearing to work just as good with a little clutch tuning. Thats all. Without traction, its worthless noThe sled that raced in shoot out had 1.68 gear ratio as it was faster then the 1.61.
Two different ratios for the 2016 track choice. I thought it was a 1.61, it wasn't.
The gearing has everything to do with racing. I don't know why your so persistent with the 1.61 axyspros8???
For what it is worth that shows up on both the Rush S and Switchback S fich.Just to confirm ... and if anyone is trying to figure this out ... if the sled has a Cobra track it's a 1.68 (22/37), and if it has a Rip2 track it's a 1.61 (23/37). This is per the online parts for the Pro-S
