Snow Flap Issues
Discussion in 'Rush/Switchback' started by Rbell14, Mar 4, 2021.
  1. Rbell14
    Rbell14 Member
    95
    Plymouth, Mi
    10
    2021 Indy VR1 850
    2016 Rush Pro S 600
    So I hate the snow flap on the Axys chassis. It runs too close the ground and often bottoms out while unloading and hitting mogules. I've had to replace the rivet that holds it up several times and now the tap has broke off.
    Anyone have a good fix beyond a bunjee cord. Guess I could bolt it on but it will rip off over time I'm sure. Maybe I should just cut it shorter so it doesn't catch...
  3. Lid1
    Lid1 Active Member
    236
    Ny
    32
    Axys
    Pdp. Long flap. With single center strap. Works perfect. I fought with those stock flaps since 19. Finally had enough. (Proven design products. ) nutvand bolt it on with stainless fasteners with small shims in center two holes. Have to drill 2 holes in flap to match tunnel. Rode 1000 ish miles with it. 0 drama andyiur friends behind you will thank you too. It doesn’t look great in hand but looks good on sled and is fitting of the machine
