Newfieguy
- 10
- 50
- Grand Fall's-Windsor, Newfoundland
- Canada
- 30
- 2002 Polaris XP sp 700 edge
going to have to look around the basement see what i can find to use to do it with
how would I know if the drive is dirty, like grease in driveshaft?It’s either your gear drive for the speedo is dirty and binds or your cable to the speedo is dirty and binding. Sounds like you keep shearing the key.
just now tried spraying WD-40 in the drive hole and then tried using the magnet again no luckYou should be able to feel it if you spin it by hand.
ok well try spinning it and checking if its dirtyYou should be able to feel it if you spin it by hand.
I never done anything with itWhat was the final solution? I have had the same problem on my 2002 Polaris Edge 800 XP SC after replacing the cable twice.
Only greases the speedo drive in that cover.Related question....... I have an 04 600 Touring. I have found mixed information whether the grease zerk on the speedo cover actually allows grease to the shaft bearing on the PTO side, or if it only lubricates the end of the speedo cable.
Bummer,,, so to keep shaft bearing lubed remove secondary and speedo cover or is there access for a grease syringe?Only greases the speedo drive in that cover.
