Stud Advise - Rush 600
Discussion in 'Rush/Switchback' started by Rbell14, Jan 21, 2020.
  1. Rbell14
    Rbell14 New Member
    21
    Plymouth, Mi
    10
    2015 Yamaha Viper RTX SE
    Looking to add studs to my Rush 600 short track (120). Wondering about how many and how long? I do 100 % trail riding and I’m looking for a nice performance level of studs. Was thinking 2 per row or 84. Don’t want to over stud and have steering issues, just want traction. Also was leaning toward Woodys Gold Diggers.
    Thoughts? Experience, suggestions...
  3. Scott B
    Scott B New Member
    15
    Oconomowoc, Wi
    43
    2018 XCR 800 RUSH
    2017 XCR 600 RUSH
    I put 2ea per row(woody's gold digger) on the XCR 600 and XCR 800. I believe that ends up being 96ea.
    I do all my riding in Wisconsin and no problems with steering using 6" carbides. I don't know which track you
    have so I can't recommend a length. I use woody's website to get the suggested part numbers and then start
    shopping on ebay. For some reason I always seem to find that some powersports down south has them in stock
    for a great price.
  4. Rbell14
    Rbell14 New Member
    21
    Plymouth, Mi
    10
    I have 1.25 lugs on a cobra track. I too used Woody's to run some estimates. They suggest 1325 series Gold Diggers. I think that give me 3/8 stud depth above the lug. On a 120 track 2 per row = 84. I think I will start with 84 and if I need more they suggest to add 2 more on every other bar on the outside to increase total studs to 126...
    You are happy with grip of 84?
  5. Scott B
    Scott B New Member
    15
    Oconomowoc, Wi
    43
    2018 XCR 800 RUSH
    2017 XCR 600 RUSH
    Hmmm. Cobra track is 1.35" 2 per row on mine and that is plenty. On hard pack it will hook up and point the skis
    to the sky. I checked the woodys website and if you check pro-s its 84ea and if you check xcr it's 96ea. Weird as they
    should both be 120" but the XCR has different drivers so I think that's the difference cause I know I installed 96.
    Do you have a pro-s?
  6. Rbell14
    Rbell14 New Member
    21
    Plymouth, Mi
    10
    Yes - AXYS 600 Pro-S Rush 120 track with 1.25 lug. Could your XCR be a 129 long track which would make sense on the 96 studs then.
  7. Scott B
    Scott B New Member
    15
    Oconomowoc, Wi
    43
    2018 XCR 800 RUSH
    2017 XCR 600 RUSH
    No 129 in a rush chassis. I did a little digging. The XCR uses a 121" track and the Pro-S uses a 120" track according to the CAMSO site. Makes
    sense now why I have 2ea per row for 96ea. I have 2ea of them so you would think I would've known!
  8. Rbell14
    Rbell14 New Member
    21
    Plymouth, Mi
    10
    Does this sled come stock with tunnel protection for studs? Under the tunnel I see two bars that I think is tunnel protection. I assume if you bottom out the track rubs on those bars preventing the studs from catching. Am I correct?
