Switched to Polaris!
Discussion in 'Indy XC' started by RHarms, Sep 2, 2019.
  1. RHarms
    RHarms New Member
    Wisconsin
    10+
    2019 XC 129 800
    Hey all, I just purchased a leftover 2019 Indy XC 129" 800 w/pidd. Anything I should be on the lookout for? I have been a Skidoo guy for quite some time now, but needed to change because I feel their sleds have gotten much cheaper made recently. Cheers!
    Trailgroomer, MrSled and Turtle like this.
  3. MrSled
    852
    Congrats on the new ride!! Post up some pictures.
    Trailgroomer likes this.
  4. coryatver
    coryatver Active Member
    378
    PA
    The rear shock adjustment knobs were falling off on them I would lock tight them on.
    A lot of them had warped rotors
    I would go over chain case adjustment and oil level, belt deflection, track tension. Make sure the shock preloads and compression settings are all correct and set to factory specifications. All of it is in manual.
    MrSled likes this.
  5. Rbell14
    Rbell14 New Member
    21
    Plymouth, Mi
    10
    2015 Yamaha Viper RTX SE
    Sold my Viper last week, will spring check a new 850 XC or XCR if available. Looking forward to something new for me. My time will be spend on this site mostly now so lets get it going strong...
    FrozenTows and Turtle like this.
  6. Bigfuse
    Bigfuse Moderator Staff Member Moderator
    607
    Sunny Manitoba
    Did they come with warped rotors or does it eventually happen? Also does the warped rotor cause the brake lever to come closer to the bar? My buddy's XCR I can pull the brake lever with my index finger and the lever won't even come close to my fingers but my lever touches my fingers and the brakes don't slow the sled down as good as my buddy's sled. Thanks.
  7. Rbell14
    Rbell14 New Member
    21
    Plymouth, Mi
    10
    I thought I recall reading the XCR has a better brake and easier lever. I'd have to check spec again
