Water Pump impeller clearance?
nomorecash
idaho
1998 Polaris RMK 600
I have a 1998 Polaris RMK 600 that I am putting back together. The water pump was shot so I took it down to the Polaris shop to have the bearings and seals pressed off and new ones back on. I didn't leave the impeller with them. Once I got it back, I went to put on the impeller on and torque it to the the 10 ft/lb required and found that the impeller now rubs on the inner casting of the housing making it difficult to turn the drive spinning the impeller. What should the clearance be between the impeller and the housing casting be? should I shim it out with another washer or take it back in and see if they can press everything a fraction of an inch more to put the shaft further into the water pump housing?
Thanks for any input and your time answering!
Mike-DRH
Hastings
2019 Polaris Rush 800
You should bring it back and have them fix it. I'm "pretty sure" if you put it back together exactly the way it came apart with the washers in the same places you can't mess it up. So maybe washers in the wrong places or bearings not seated properly. You should bring the impeller with.
nomorecash
idaho
Thanks, That is what I did, took it back. Everything was there, washers ,etc... We found if a second washer was added we could get the clearance I need. Thanks again for the feed back!
