Chiefcheese
- Messages
- 246
- Age
- 62
- Location
- Wisconsin
- Country
- USA
- Years Snowmobiling
- 45+
- Snowmobile
- 15 Anny Rush 800, 16 PRR LE Switch 800
Yee ouch
Machine for overdrive, balance and rebuild my axys clutch........ $380 later
Does he recess the spring pocket for the extra thickness of the shim?
Machining for OD is just that , pushes for more top end.Question, with a machined primary for more overdrive, lets say you don't touch your gearing at all. W/o gearing down, and machining your clutch for more overdrive, could it effect RPM's throughout the shift band and impact performance and top speed (make top speed and RPM's worse since you didn't gear down)?
