You can yes, clean up fuel and timing will probably add 2-4 hp plus torqueBrock,
Do you significant performance benefit in adding the pcv to the stock exhaust?
Brock can I get the pcv from dtr with a map to run stock exhaust and a map to run with pipe when I get one??You can yes, clean up fuel and timing will probably add 2-4 hp plus torque
If you have a subscription to dtr. Look how the stock exhaust shines from 7300 to 8000 rpm. It's a low and mid grunt pipe like I mentioned earlier. It beats a lot of pipes that were just bolted on in that area. Pcv is the key with the bmp and ssi to make better gains .
Think the Pcv only holds 2, i may be wrong? But i think it holds stock tune and your hot tune. Im not sure on a 3rd? I didn't see anything about more then 2 on PcV websiteBrock can I get the pcv from dtr with a map to run stock exhaust and a map to run with pipe when I get one??
I
My question is a 16gb usb good enough to hold a couple tunes if have more then one? Or just get a 32gb? I have a new 16gb that i got for idd that i never used. So wondering if i should just get a 32
Oh ok, thanksPretty sure the only way to load a new map is with a laptop, don't believe it's possible to store one on a flash drive and transfer directly to your power commander.
I just talked to Jim about this as we did a few Pcv maps on stock motor and stock exhaust. He confirmed yes.This was done earlier this year, not this pipe shoot out.Brock,
I'm almost positive the pcv can hold 2 maps and they sell a switch that allows you to toggle back an forth between maps. So if this holds true you could go from no pipe tune then spring on a pipe and flip switch to pipe tune. or from say a 1000 ft race tune to a very trail friendly tune. I want to say I guy I used to ride Harley with had pcv with switch and one tune was for riding normal and the other was for nitrous in case he got rowdy. LolBrock can I get the pcv from dtr with a map to run stock exhaust and a map to run with pipe when I get one??
