Stormrider3
Many phone chargers are 5 volt output, DC. Hook directly to the TPS, and use fluke meter to set
True as we all talked about,but I never tested it this complete way. I think it's more accurate and close if not the same as a dw. I need a dw side by side comparison to be 100% sure now.I thought we determined the Digital Wrench would read different and would be more accurate thank a multimeter?
The heat shield plug that you can buy has the same white 2 pin plug. I don't see any others on the Polaris site that works???Regarding the ecu power up cable, does anyone have a source for the connector that hooks up to the ecu pigtail on the sled? I'm looking for a part number and vender.
With the plug, it would be simple to build your own power up cable. It looks to be the same as the gauge power up plug.
On EBay I purchased a TPS wire harness used for testing a Polaris TPS and then a few days later ordered a High Quality "ECU power up cable" from Tonka1020, high quality & quick delivery...Regarding the ecu power up cable, does anyone have a source for the connector that hooks up to the ecu pigtail on the sled? I'm looking for a part number and vender.
I believe a $400 PCV or a SLP $250 PCFC fuel controller would be more accurate then a multi meter.... I will compare my $120 Fluke meter to my SLP $250 PCFC fuel controller... After a friend returns my ECU power up cable & my TPS wire harness adapter tester...I thought we determined the Digital Wrench would read different and would be more accurate thank a multimeter?
Brock, Thanks for your input that the fuel controllers are not very accurate for measuring TPS voltage even though they read out voltage to 3 places (with my PCFC, WOT 4.222 volts) unlike my old Sears or new Fluke multi meters that only read out 2 places such as 4.22 volts, or my cheap $8.98 multimeter base at .687222 volts??? LOL ....Pcv doesn't read the same as digital wrench or multi meter. It's very inaccurate for reading tps. Tried it side by side with digital wrench.
Thanks for a your info though
