Where to start on MY clutching
I'm sorry I don't understand smaller is better.
lol, my bad. I have two equal in spring rates, springs,,, and the Polaris spring is smaller in diameter and sits a little shorter. I was wondering if the double shot peened had anything to do with it. The springs are a 155/222, one is a team the other a polaris
Smaller in diameter? Do you mean the wire diameter or the outside diameter of the spring itself? Same rate springs with different heights and different wire diameter will shift differently.
Ya I was wrong, my buddy said it was a 155/222, I checked by Polaris color and its a 123/203
Why are there so many Poo primary springs breaking. Mine was broken on my Indy in the second year.
IF YOUR SLED CAN HOLD GOOD RPM, DONT BOTHER WITH ADDING MORE FINISH TENSION THIS WILL KEEP THE SECONDARY FROM FULLY OPENING OR JUST SLOW THE LAST BIT OF THE SHIFT DOWN. WEAKER SPRINGS USUALLY WORK BEST FOR ACCELERATION, HOWEVER IF YOUR JUST LACKING A BIT OF RPM ON THE BIG END THIS SPRING WOULD HELP. CANT HURT TO TRY IT OUT,ONE NEVER KNOWS...
