OutCast
Who has lined up them AXYS with an INDY...
What size track is on the Assault? They are known to be the sleepers of the Polaris 800sI was anxious to see some line up at the Eastern Nationals last month..but to my surprise I did not see 1 newer Polaris..Was bummed out for sure..I have ran my buddies 800 Assault numerous times, He doesn't fair vary well, but he keeps trying..
And with my INDY I destroy my Buddies AXYS and another Pro X does a little better but still not close to my INDY.
They usually come with a 1 3/8 Cobra Eddie. And they are sneaky fast on top end. A friend of mine had his speedo indicating 116 mph on Hero snow.What size track is on the Assault? They are known to be the sleepers of the Polaris 800s
A tuned radar gun and timing system. We mark out area's on the lake and good for all winter.Speedo 112 or GPS, radar gun?
My pro s switch. I had it doing 112 mph in 1200' last year on ice. It toke some clutching,gearing,suspension tweaks to do it. But it's fast now.
Slower. They're already geared way too high to begin with.is that with lower gearing. Wonder what it would do with higher gearing
You won't loose top end you will gain top end. With stock gearing all that I could get for mph was 106 and the belt never went to the top of the primary. When I geared mine down to 1.74 I gained 6 miles per hour and because the engine didn't have to overcome that tall gearing and the belt went to the top of the primary. Remember the secondary is torque sensing. If it senses a heavy load it won't let the primary shift all of the way out. The Pro X has to turn a taller lugged track that is 1.75 inches vs. the Pro S which has a track with lugs that are 1/2 inch shorter hence the lower gearing. Ideal gearing for the Pro X would be 1.81. When I geared mine lower I factored in 10% overdrive which would give me around 112 mph.Im leaving it stock and adding SLP. I just want to blow my buddy away he has a cat 800. don't really want to gear down and lose top end. Have heard the Pro X which has the lower gears has low top end
Just a 40 tooth bottom gear and a 70 pitch HYVO chain.where do you get gears at? order polaris oem part gears? need a new chain also?
I got mine from my dealer or you can get them from Team.Ok thanks where can I get them from
Do you have a Pro S or Pro X?looks like the pro x has a 70 pitch chain and I can use that. but they have 41 tooth bottom sprocket. Does anyone have the polaris part number for the bottom gear?
