Wont start without unplugging capacitor
First thank you for the information above
I was going to tell you the dc amp draw from the pump but my meter has a blown fuse. I soon I get a new fuse for the fluke meter I will let you know.
Your problem is the red wire to the relay coming from the VR, if no 14.6 vdcs from VR you will not have pump or gauges, the red wire feed the relay in turn feed the red/white to your console, there is also a red/ dark blue to the pin 33 (ecu). please note the red wire feeds the pump directly no thru the relay. check voltage from the VR . Also check from the 6 pin not the 3 pin from VR. The 3 pin is the to charge to battery if you do have a electric start. If you need the diagram let me know. One more thing, if you dont have proper voltage coming from the VR, you CAP will not charge to 14..6vdc and will not keep voltage up to get the reverse going while your engine goes dead to reverse .
Also see quantum for fuel pump......$80 your price
Hope this help
Pro
welcome to my nightmare
ProTurbo
- I think I understand what your laying out for connections, my connections are close to what you called out. I have the wiring diagram blown up to 4x 11x17 sheets of paper, printed off and taking up with kitchen table, the image is so large I can not attach it to this forum, otherwise I would.
-Tonight I unplugged the capacitor, unplugged the 6 pin plug to the voltage regulator and powered the ECM plug with a 12v battery. Sled fires right up and runs on the old (plastic volcano) ECU and most importantly the ECU does not get hot or smoke!
-Thinking about this more... I'm thinking I should just leave a probe on a ground wire and check every wire that should be "HOT" to the ground and see if I have a short. I checked every wire for continuity Sunday, took 4 hours, this was going point to point which would not highlight a "short".
ProTurbo- Did you get your sled fixed with replacement harness?
850 Switchback
-The sled has not been in for the recall. Pump still works fine on battery power (see details above). The pickup sock and inline fuel filter have both been changed within 1000 miles, also had the pump out of the tank and looked at the pickup sock and bottom of the tank, white and clean. Lastly, I have experienced the pump whine before due to bad gas at a station and it in turn throwing a DET code due to a plugged fuel sock, so I am familiar.
Thank you for the help!
ProTurbo
No I didn't get a hardness yet, Looking to get a new fuel pump, but I doubt if it will fix my problem since I'm cannot getting 14.6 vdc out of the Red wire off the VR even when I have the whole hardness not plugged into the RED wire. Anyone had a match I can borrow
Found this article today... really hoping I don't have two fried ecus...
Thank you for sharing information, I hope I don't have that problem also.
Went to a dealer today as I am at my witts end, explained to them everything I have been through troubleshooting. After speaking with the service manager and a senior tech, they declined to take my sled. They were being nice, stating that based on what I have tried, they would do one of the following...
-unplug the dash and try starting
-buy a new harness
Just thought I would share
So just a thought based on that, try unplugging just the ignition switch and run the machine. See if the voltage improves.
They've been known to corrode internally and cause weird issues for others
Did just that tonight, no luck.
Just cut all the tape and loom off my harness, didnt find anything but could not believe how terribly twisted the wires were when they were taped would not doubt if there was a bad wire in the mess. Hooked up the harness to the sled in the dark, no electrical shorts or jumps that I could see. Hooked up spare ECU finally, sled ran for 2 minutes, voltage looked good at DC and ECM plug. Then the sled started to ramp up in idle and before I could kill it, the ECU popped and let the smoke out of it violently.
I'm defeated, ready to part it out.
That sucks and very confusing since the ECU is powered directly off its separate isolated circuit on the stator, and you already changed a stator.
-buy a new harness
Ya Bummer man. looking for one also. thank you
no kidding , lol Sounds good, Im up for anything right now. will be home tomorrow. yes we did swap the stator and flywheel. same result
Thx man
will let you know for sure thank you, so she will run without plugged in. ok
off the cap 6 VDC with it
sorry to say, same thing, 6 VDC off the cap. waiting for a new harness
SOLVE
Replace the wiring harness and Voila.
Started with cap on and has reverse
Thank you everyone who help out, much appreciated....
