If you have a 1.75" lug track, I would be using a 1.80 gear ratio or lower. That's the first thing to do.
then clutch.
That 1.75 track is like a big fan that has to move a lot of air. Air is resistance that's why you'll need 1.80 gear ratio or lower.How much would that hurt my top speed?
THAT SLED STOCK COMES WITH 22-41 GEARING AT 8350RPM AT 1 TO 1 RATIO(NVERDRIVE) 97.1 IS MAX MPH..SO WITH 5%OVERDRIVE YOUR RIGHT AROUND 102.
I'd also recommend a Gates belt part number 46C4387 as it goes higher in the primary than the stock Polaris belt. Also with this belt you'll have to add two extra grams of weight in the primary.The pro x comes with a 22/41 = 1.86 ratio.
The pro s comes with a 23/37= 1.61 ratio.
With your 1.75" lug track,I would use 21//38, 68 pitch chain. This is a 1.81 ratio.
1:1 ratio @ 8300 RPM gets you 99 mph.
Add 5 or 10% over drive( full shift out) and your 104 mph @5% over drive. 109 mph @ 10% over drive.
By full shift out. That means marking your primary with black marker and there's nothing left at top of primary.
Yes .015 to .025 max must be done to help push the sheives closer together to work the belt all the way to the top so it starts to ride just above the outer circumfrance
It's all of the little stuff that you have to do before you start putting on power adders.And if you mashing the clutch and get the two sheives to come closer together at full shift that's where you can pick up some overdrive
