Couple of questions.I have the SLP pipe and can, and I just like SLP and always had great luck with there stuff. I payed more for it, and it is easier to keep clean and looking nice. But who really looks, (me) lol... I have never had mine dynoed. But I can tell that through the testing that I have done the modded pipe will make more HP in non eth mode. But the biggest thing that I have learned is the best thing to do first is get your clutching perfect!! Now I suck at clutching. So I listen to what guys are saying and apply it to my sled. The pipe and can is just an extra little bonus. 160 ish HP with a perfect set of gears and clutch work will make the world of difference! I have the SLP stage 2 clutch kit as well and have done some work. Still up in the air with a total clutch change...
So you're doubting his gains?Terra Alps shows the stock Axys making 145 hp on his dyno.... so of course his magic pipe makes 11-12 hp.
No when or if Dynotech does an independent test. Brock and dr.notadoo will be doing some testing this November or December. Why would you doubt Ted's gains? His engines and pipes are used in some of the winning Polaris RMSHA sleds. Time will tell.Short answer.....yes. We will see how it stacks up when/if DTR does an independent test.
I always doubt anything over 8 hp on a single pipe. But this 800 ho pipe has left a lot on the table. Stock pipe is made for low end grunt and mid range power. Not made for top end . So that being said, . After market can do a lot with a better design. Add a fuel controller and 4 hp more.Short answer.....yes. We will see how it stacks up when/if DTR does an independent test.
So have you kept the pipe on or did you go back to stock?I had an SLP pipe and can that I dynoed and ran one wkend. That pipe will work with the stock canister with no power loss. It's a lot quieter then there can. It passes the db test but it was to noisy for me. Some tab adjustment will be necessary with the pipe and stock canister combo
Sorry Dave, I assumed every one would get it .Well Brock you did not state that the pipe continued to make hp above where you cut it off. How are we to know?
How wide is Bikeman's horsepower and torque window?just too add more fuel too the fire BMP is saying plus 12 ....
I'm pretty well waiting for DTR dyno numbers myself.Haven't seen a sheet with just the pipe , they have a graph floating around with a bunch of shit done too sled , website says plus 12 with just the pipe , like another member said I'll believe it when it hits DTR.
