- Messages
- 1,087
- Age
- 69
- Location
- Will County, Illinois
- Country
- USA
- Years Snowmobiling
- since 1976
- Snowmobile
- AXYS Switcher 800,Indy600sp,XCSP600ves
Jim, he has to be cutting where the heel rest's. Poo tips don't touch anything.
I'm thinking he meant the tip of the heel where it rests.Jim, he has to be cutting where the heel rest's. Poo tips don't touch anything.
Really???If the gates is that much wider I would need to reshim my primary. For the first time I have ever seen,,,the clutch on my axys did not require reshimming/indexing. I'm right at .015" with a new 1177 belt.
machining the spider changes pin height(tucking the weights),grinding heels,etc.........I've seen on some Polaris clutch's were the weights rest on the tips. I'm off to the races, I'll try and make time this week to get pics.
I don't have a set of slp weights to compare with 11 series right now.![]()
Thanks.I doo, if I can make the time I'll do a comparison.
Lets assume a person has two identical belts, but the pitch length on one is either shorter or longer than the other? What in theory would be faster - the shorter pitch length or longer pitch length?
Just pulled my clutch, did as written above and I can get a .025 feller guage in. Unfortunately that's as big as my set goes. Don't have a spider/ spider nut tool to pull it to remove shims. Clutch will have to stay the same until I can or parts in. Unless someone is close to Waterloo Ontario that could help a brother out?Feeler gauge. Belt has to be pushed against either sheave of the primary. I like to check them with the primary on the bench. Wrap the belt around, and tighten it with a tie wrap to make the belt as small as possible in the clutch.then measure
On a side note to this, the newer belt I have on now is 1.414 and old spare belt that came with the sled is. 1.406.Just pulled my clutch, did as written above and I can get a .025 feller guage in. Unfortunately that's as big as my set goes. Don't have a spider/ spider nut tool to pull it to remove shims. Clutch will have to stay the same until I can or parts in. Unless someone is close to Waterloo Ontario that could help a brother out?
