Indy 600 clutching
buddy330
maine
2016 indy 600 sp, 2017 indy 600 sp es
Changing from the 11-64 to 10-64's did not change topend rpm. Still dead nuts on 7950. Last time I did not check mph. This time I watched speedo right at 100mph and gps said max speed of 98. So I have a baseline there. I just changed the secondary spring to a 140-220 blk green Same road tomorrow, pretty much same conditions and same amount of gas will be in tank. Will see if I gain some rpm and if that equal more topend mph.
Dave, how did that secondary work ?
racerdave
Moderator
Moderator
Will County, Illinois
since 1976
Lost 2 mph on top. Down to 96 mph GPS but snappier midrange. Tradeoff??
buddy330
maine
I'll gladly shave a couple of mph to get a good trail set up. I'm currently running 140-310, 10-64, 140-240, 48-44F. This is working well so far.
buddy330
maine
racerdave
Moderator
Moderator
since 1976
Have you tried keeping the rpm's at 8,000? That is where the power peak is on the dyno tests I have seen.
buddy330
maine
8100 is about the slowest I've turned it. I think I'll dig out the radar gun and see where these things make best power.
buddy330
maine
changed out the 10-64 to heavy 10-66, (66.5 grams). 8050 to 8100. Pulls way harder at this RPM against my '17 600.
Brett
PEI
2015 Indy SP LE 600
2005 XC SP 600
1996 XCR 440 SP
1989 Indy Sport 340
Buddy330 did you test both your sleds side by side to see the improvements?
buddy330
maine
Yes I did Brett. With the combo in post 103 I could roll by my '17 without much problem at 8200. This was in northern Maine at near zero temps. The rpm I gave in post 105 was in the western part of the state, 2000' ish so rpm was down, I never gave it a thought until I saw 8200 up north at close to sea level. Changing to the 10-66 weights dropped rpm and just drives by my '17, it's not even close. You and Racerdave are on to something here.
Brett
PEI
2015 Indy SP LE 600
2005 XC SP 600
1996 XCR 440 SP
1989 Indy Sport 340
Nsp helix and my own setup springs weight and gears. Too high engagement. Causing track spin.
Nsp helix and my own setup springs weight and gears. Took engagement down. Geared different from first setup. Ran this setup atleast 12 times back to back. Test sled hasn't been touched throughout all the testing.
Running well over 660' here. Xc still pulling hard.
racerdave
Moderator
Moderator
since 1976
Unless he changed hoods that isn't a 98 XC7 twin. Looks like a 600 monobloc triple hood. Less than 100 hp stock.
Brett
PEI
2015 Indy SP LE 600
2005 XC SP 600
1996 XCR 440 SP
1989 Indy Sport 340
Yes hood has been changed. Original was smashed. Yes it's a 98 xc 700
racerdave
Moderator
Moderator
since 1976
The 600 had less than 100hp stock? I have never followed the older Chassis sleds/motors.
Yes, the 94.5 and 95 XCR600 monobloc and 96-97 XC600 monobloc triples were around 95-98 hp.
Brett
PEI
2015 Indy SP LE 600
2005 XC SP 600
1996 XCR 440 SP
1989 Indy Sport 340
98 xc 700 is around 125 hp with slp single pipe according to dyno charts. So very similar in hp to the Indy 600.
racerdave
Moderator
Moderator
since 1976
Where have you seen a Indy 600 stock making 125 hp?
Brett
PEI
2015 Indy SP LE 600
2005 XC SP 600
1996 XCR 440 SP
1989 Indy Sport 340
Never. Just saying there close. Stock Indy 600 is 114-118 hp roughly depending on who's dyno chart ya go by.
racerdave
Moderator
Moderator
since 1976
Just happened to come back here. For what it's worth, the 98's Xtra 10 rear skid is better for topend running than the Indys long travel rear skid. Probably even up in a short drag
