Kerrdog569
Did you pull your plugs and check for spark?I had spark but mine wouldn't start til I held the throttle wide open, starts now but seems to idle a little funny,and I need to crack the throttle a tiny bit sometimes when its warm,I pulled the pcv off and the ssi head to see if it goes away,never did it beforeWell I tryed plugging in my pvc and no luck will not start.. I read this post a few times to make sure the plugs are right.. I even tryed not plugging in the coils.. just the main pvc plug to the ecu. And still no start. I checked the ground it good. Any help would be great.
