Ok Guy'S, 2 good ride so far (600km) on my new Setup, still need fine tuning tho. On groomed trail all i can see is 153Km/h (gps) and on hardpack the max i'm able to put is 162km/h, Rpm is around 8100 steady and on best pull with very cold temp (-30) was 8200 but just couple of time. Sled seem to pull hard but when comparing to my friend XRS (no change from last year apart a gate's belt') it's the same result as last year..Look like i gained almost nothing, maybe a little more top end if so.
Any Idea ??
Setup so far
1.76 ratio with 10-68
120-310 spring primary
50/44fp with 140-220 spring
gates belt
belt to sheave at .20
1.5 deg timing keys
Chain and track set looser than stock
I have modded my stock 10-66 to 69.5 like said above, still need to try these..!
