- 1,087
- 68
- Will County, Illinois
- USA
- since 1976
- AXYS Switcher 800,Indy600sp,XCSP600ves
Neal as long as you are here, why no pipe mod for the AXYS 800?
Neal, the number for bully dog program is #rms5l3c.atv.Brock, would you be able to find out what file they were running on the dyno? (It would be located inside the USER folder on the SD card) My guess is it was an earlier tune. We've made several revisions throughout the season to further improve the mapping. Shouldn't be any lean spots or need for an additional fuel controller.
Neal if I get the bully dog for all the bikeman stuff I have now how often do you come out with new tunes and do you post somewhere when you do so I can always keep my sled up to date?Glad you asked that. We have found with this particular pipe that it is highly prone to detonation when doing a pipe mod. We can do a pipe mod that makes power but it's not rocket science, you're adding an internal stinger and adding length to it to create the power you want through backpressure. On a loose pipe this is fine (such as older models that we still do pipe mods for) but on an AXYS pipe it's just not the right way to do it. It's much better to create power through sound waves and we took the extra time to do it right with our pipe. Any other questions feel free to let me know.
That's an older tune, we're on RMS5L*D.ATV right now. If anyone has our Bully Dog and is running an older revision please send me an e-mail with your name (or name/company the Bully Dog was purchased under) and I can send an updated tune through e-mail. You can easily check which tune is on your unit by taking the micro SD memory card out of the Bully Dog and hook it up to your computer using an adapter. Open up the SD card on the computer and open the USER folder. This contains your custom tune(s).
On the bold. So why does your pipe for the AXYS have an internal stinger if it causes detonation?Glad you asked that. We have found with this particular pipe that it is highly prone to detonation when doing a pipe mod. We can do a pipe mod that makes power but it's not rocket science, you're adding an internal stinger and adding length to it to create the power you want through backpressure. On a loose pipe this is fine (such as older models that we still do pipe mods for) but on an AXYS pipe it's just not the right way to do it. It's much better to create power through sound waves and we took the extra time to do it right with our pipe. Any other questions feel free to let me know.
So can the BMP pipe be run on a 15 with no fuel controller and no det's?
I looked in my pipe today and I don't see any 90 degree bends in it. Where do you see 90 degree bends in yours?Its half as long and no 90 degree bends
Just for reference, the SSI stinger is made of 3 pieces (straight then a bend followed by a shorter straight piece).
Yes, there is a welded bend inside the pipe. (Which I wonder how much more back pressure that creates compared to having a rounded bend. The BMP is slightly wider, shorter and doesn't have the bend.) What I was meaning to check and see if there is a dent (in the tubing), weld bead, weld slag and or etc. inside the internal stinger outlet that could be causing additional resistance.
I was looking at modding stock pipes earlier this winter.
The end of the pipe itself turns down towards the silencer. I believe the are trying to get the stinger to line better up with the main body of the pipe. Look up from the end of the pipe and double check one of these pieces is not broke off inside the pipe.
I ran my SLP stage 2 against Bikeman pipe, SSI pipe mod, in the field and they all ran about the same. The pipe mod guys are complaining about the det coming on.Jim, thats their claims. Real world experience is what i am asking for.
Nowhere is there a 90 degree bend in the stinger Cory. There are bends but none of the guys you quoted said that there are 90 degree bends. I looked up mine yesterday and there are bends but definately not 90 degree bends. Did you by chance look up your pipe and see a 90 degree bend?These guys that know more than me said it does. In the other thread
So then buy a Bikeman pipe if you think that will solve your problem.I did look up the pipe did not see all the way up in there and did not cut it apart to look just taking peoples word for it I apparently misunderstood. Point being whatever is up in there it doesn't work on my sled and many others and the bikeman does
