Installed scratchers incase i ever need them. Last yrs 2016 assault i never had any issues with overheating and it was end of yr and no snow in some spots. Id rather have them THEN not have them and need them. I did not want to remove any wheels.
Customer wanted me to install normal scratchers on his. Removed front wheels and Even then they still dont install 100%. The top wheel will come down and hit the wire on full compression if that will ever happen on the new suspension.
I installed Skidoo summit scratchers. Can also reverse with these if you want. You will need 2 stainless 5/16" Eye bolts. 2x nylocks for them. 2X none nylocks for them. 2X thick washers for them. Also 2X 1/4 bolts 3.25" long or 3.5". couple washers and locknuts.
Remove the rear inner wheel bolts. Dont need bolts anymore. to short. Install the summit spring bracket mount with the new 3.25" bolts. tighten up. Then drill the 2nd hole for the new summit bolts that come in kit. No pic of that. New bolt holds the spring and the bracket.
Cut just less then half of the eye bolt off. No less. For a reason in the next step. Drill holes for eye bolts. Get thick stainless washer and cut enough off so washer sits flat just above sliders. Have to adjust how far it sticks out next
install it loose with nuts so you can adjust how far they stick out. You need to have them out in the right spot so when the top wheels comes down and you actually bottom out the wheel will actually go half way into the eyebolt. Thats why you have to cut half or just less then half off the eye bolt.
Use a straight edge on top wheel and it will show you how far out to put the hook so wheel can go into it. You will have to hit something pretty hard to bottom out wheel all the way down. Unlikely but just incase.
Install the Trail version clutch kit from northstar performance. Helix, both springs, weights, bushings. And got the spyder shim kit from catzass.net .
I always make my own marks on clutch so it goes back together the same position for balance.
Swap provided weights. Install the spyder shims on the thrust side of the weights. Gets rid of the sloppy side to side play. Makes a Big difference. It takes a bit of time getting the shims in right spot to get bolt through. Install the new white spring. Put cover on in the right position for balance.
Heres the reason i did the intake update kit. Pulled hood off a sled that was outside today and theres water dripping down to crack that can get into intake
