in the red
The cvt system is ONLY in backshift when when throttle is let off and put back on. In this instance the cvt system is in backshift mode ONLY. When a steady throttle position is applied the cvt system is only upshifting and this is were the lower gear ratio does come into play as it will upshift quicker and have a quicker response. Gearing means everything.
By that term analogy that you just mentioned
"gearing has nothing to do at slower speed". I guess ALL the sno x teams should have there sleds geared for 112 mph at 8250 rpm on the sno x track(1.61 ratio)?????? I guess sno x teams have been doing it all wrong for all these years by gearing to 70 and 80 mph at their peak rpm???
I'm not arguing with you, I'm just trying to prove a point about how efficient a lower gear ratio can be.
Ind the end, it's your choice on any changes made my friend.
