Clutching and gearing
Did you go? That bad
Yes, not worth the 7hr ride. I had to go to get other sleds ready. Rode 45miles, water holes here, there, rocks sticking out where groomed. Where it wasn't groomed was most snow. But was bumpy.
Ok, where did you go?
1.67 ratio with studs in track .
I would tend to agree with that ratio on a one inch hacksaw.
Let me throw this out there for tuning.
Gear down slightly
Start with stock helix and spring
Start with stock primary spring
Dalton adjustable weights or other brand adjustable.
Adjust engagement " if necessary " by notching weights.
All tuning with a pipe.
Thoughts ?
Yes they are, Brock posted a pic somewhere on this site of a few weights showing the profiles. I've never used them, but they seam popular to a lot of people
They're really easy to tune.
Would Daltons adjustable weights be a better choice than the 10-70, I thought I heard they were a more aggressive ramp
The 10-70 weights don't have enough tip mass. That's where the Daltons work really well as you can load the heel for better belt pinch at engagement and tip mass to fully shift out. I highly recommend them.
JUST today got my Daltons. I will end up running a Terra-Alps head/pistons and an SSI pipe and PCV with a Dynotech matched map. Also the usually recommended 50/44 helix; 120/310 primary and the recommended secondary--was it 120/200? Geared down to 1.74 and added a 1.5 Ripsaw 2 to replace the 1.25 Ripsaw 2 on my AXYS SW S 800.
Can you please recommend a loading profile for the Dalton primary weights as a starting point?
Ttraynor , what's your weight and are you Studding the track??
ON THE SPRING YOU MAY NEED A FEW 140-200 WORKED WITH 10 SERIES PROFILE, MAY NEED A TOUCH MORE WITH A TUCKED WEIGHT. 155-222 FOR EXAMPLE
Sorry for the late reply. I weigh 160-170 and no studs.
With all you got going on. I would load the tip weight of those daltons and heel to get you somewhere around 71 to 72 grams to start. From what I'm seeing in your mods you need to rev 8400 rpm.
Try a 120/300 or a 120/310 primary spring.
Use that full progressive helix with a140/200 like doc said. If you feel it's lazy in back shift, use a 140/220 or a 155/222.
Try it Div20
Try it Div20
Awesome info and site! But can't we argue about it a little? LOL
