Nortrider
- 118
- 38
- Fort Kent Maine
- USA
- 1994- now
- 16 pro s ltd
What about 52-46 full?
The ones that are suffering is in the cvt system, it's not the engine performance. Poor set ups and inconsistent polaris belts,tall gear ratio,primary qc..Yup! A 16 pro s ltd. I was skeptical about getting it because there's been a few 15's around and some are good hard runners and some are just complete dogs. But so far so good!
Now that winter finally made it to new England I should be riding in a week. Im fairly new to clutch tuning and I made a lot of changes to my sled (with the help of you guys on psp). Geared to 1.74 with iq roller, 120/310 w/cutler adjustables, 50/44 with 140/200 sec, and gates belt. Checked clutch alignment, belt clearance, track tension. Im pretty confident that you guys steered me in the right direction but if I have any problems I need to know how to troubleshoot. Im guessing the only problem I will encounter will be rpm's. I've read to keep throwing weight to it till it falls on its face then back off. Anything else I should keep in mind????
No Problem but you sure you wanna se guys riding when you cant?? lolYes. The majority of us midwest trail riders still have no real snow to ride. So we need pics of you out on the trails.
Damn right. Sled porn!!!No Problem but you sure you wanna se guys riding when you cant?? lol
So can anything else be wrong? Just fine tune weight? Once I know what I need(with gates) for weight im gonna weld my stock ones to suitDamn right. Sled porn!!!
I would try a 120/300 polaris blue in primary and a 140/220 spring in secondary.I went out for a ride today and sled goes good! I installed the 50-44f helis with 140-200 spring. My primary clutch has stock spring with 68 gram weights. So when I had the stock helix and spring it pulled 8300 all day long. Now with the 50-44f helix its down to 7900 to 8150 rpm. I wonder if I put a stiffer spring in the primary if the rpm will go back up.
I would just try a primary spring first youll be going from a 270 too a 300 that should more then adequate for getting your rpms up ......I went out for a ride today and sled goes good! I installed the 50-44f helis with 140-200 spring. My primary clutch has stock spring with 68 gram weights. So when I had the stock helix and spring it pulled 8300 all day long. Now with the 50-44f helix its down to 7900 to 8150 rpm. I wonder if I put a stiffer spring in the primary if the rpm will go back up.
