- 1,087
- 69
- Will County, Illinois
- USA
- since 1976
- AXYS Switcher 800,Indy600sp,XCSP600ves
You are right Heath. I missed that one on the chart.24/40 IS 1.67 AND .25 CHAIN SLACK
RD how about the chain case cover bolts?Torque: Clutch cover 100 inch pd's 11 nm, helix torx screws 8.3 to 10 ft pd's loctite 243 or 242 with primer, gear 29 ft pd's, brake rotor 40 ft pd's, caliper bolts 40 ft pd's loctite 242. I keep the bolts on hand that use a nyloc patch same for nyloc nuts. They should be replaced each time removed, at the very least after the second use in my opinion.
Lots of Bloody Marys and beer.![]()
Thanks for the advice but it was pretty easy, only took 2 odoulls.Bloody Marys and beer.
I went with the 50/44Got my 48-44f helix this morning. Now the wait gets longer.
Venom should have one.I found this one on ebay. Team won't have/make either till January from e mails with them. I will order a 50-44f then. Could not find any at Goodwins,HPE, or Wahl. I will give this one a try on the 800 and then the 600.
Oh ya I forgot venom is team. I guess I lucked out when I got mine from them a week ago.Venom should have one.
Thanks for all the tips, cant wait to run with my buddy who thinks changing springs will do the same as the gear change. Winter is a little slow to start over here in new England but im ready. Only thing I need to figure out is the cutler weights and belt clearance.Rd and popo ,u guys will both like those full progressive helixs as doc said. It will back shift really well in the trails vs the compound helix. And give u great up shift. I think you'll be happy.
Think you want a 140-200 with a 50 startAll done, gear to 1.74 120/310 with cutler adjustables, 50/44 120/200 on secondary. Just add snow
Your right flash, it was a typo. Hey my buddy wants to keep stock gearing (for now) but wants better springs in his clutches. We put a 120/310 in and I have a 155/ 222 for the secondary. Will that work or do I need a different one for the secondary??Think you want a 140-200 with a 50 start
