. From a dead stop you should be out accelerating the stock geared sled if you have traction.remember here guys there are two ways to load the motor one is chain case and the other is clutches. There needs to be a balance between the two, taking some from the chain case , you will need to add load to make your clutches work harder. .
In the yellow.
You're 100% correct doc.
If you guys think properly set up 1.61 ratio sled is going to beat a properly set up 1.74 ratio sled from a dead stop to 660' ,800' , or even a1000'.??? Sorry but that's wrong, timing systems don't lie.
If that was the case. Then all the pro grass draggers would use a 1.61 ratio and be done. No need to change gearing???
Way to many things going on,suspension,belt, belt slippage,belt getting sucked down in secondary due to improper weights/spring tension, traction, etc.....
In the yellow.
