Dr.Notadoo
ok then this makes sence, the higher reving 17s is from less timing on the big end. that's where the other 200 rpm are coming from..desired and actual are going to remain less then a 15,or 16.IMO
Did spi respond to timing or was it still making 0 hp?
We had no time to test the 911. So many pipes tested on the stocker took us 12 plus hours . We Will probably bring the 911 back up in mid December with Brock's sled when he gets it ready. Tests on those 2 sleds will be a bit more similar . That will help us save on Dyno time.How did that 911 do????
Jim starts the run when the pipe temp reaches 850 degrees and the engine temp is around 90 degrees . Then we run it hard for a minute plus till engine temp is 145 + degrees and pipe temp was reaching 1140-1160 degrees
Engine temp is controlled by flow of coolant at jims so we can run it hard for a minute plus without over heating . T stat is pulled to help.
We pound on it hard to find we're everything works best . Then we pass on the the knowledge to you guys .![]()
We toke a new 17 there because Jim wanted us too, to see differences in model years in break in mode . That simple.Just curious but why even bother testing in break-in mode? Also, was the BMP pipe held for long periods of time? I noticed you just mentioned Jaws and Terra Alps being held open for a long period, not the others.
Don't you guys have a bd that takes out break in mode ??
