Tim there are sled lengths in the secondary.Im not sure why Slp dident put a helix in with the stage 2 kit..however depending on your riding style you have options...If you want to use the stock sec. spring and gain some mid-range as you asked you need to load the sec. harder to make the motor work..a 58-44/.46 is a mild choice and will gain in the mid. that .100 makes a difference... your stock helix is (58-44/.36) the first 2 numbers means its partially progressive for the duration of the last # and thats why the .46 works better because its loading the sec. longer..the 44 is the finish angle for the duration of the clutch opening..my suggestion considering your using Slp MTX weights in the primary is to put a 50-44 full progressive helix with a 140-200 sec. spring..ive dynoed an Axys with the Slp pipe and 8300 is the RPM your looking for..the sled lost 5 hp at 8400..and keep weight in the tip of those weights ,leave the mid open , if it over reves put a 3gram rivet in the tip and back off on the hi tension primary spring it comes with be in the 290 -310 range..IMO i can back all this info up
Good choice in helix, works very well in backshifting through the trails and gets you the upshift you need to lay it down on your buddies.
I like the 70/44.46 and the 66/44.46 helix also
Weights are your main tuning tool, springs are your fine tuning
